Belts not displaying
Posted: Wed Jan 04, 2023 9:09 am
by BillM
I created a timing belt example similar to the one you created in your Ticker Introduction (Part 4, ~time 27:55).
I used the default Timing Pulley object creation for a T20N pulley wheel/pinion pair. I copied the pinion so I could do a 3-pulley system. Selected the pulleys in a CCW and then linked the selected pulleys. No belt was displayed. I verified that the pulleys were connected by running the simulation with cartesians selected.
I have also loaded your example Collections project file and noticed that the belt between the timing pulleys was also missing. I don't know if this is a graphics card issue or a software issue.
My computer is a Dell 7506 2n1 computer running Windows 10.
Bill Michael
Re: Belts not displaying
Posted: Wed Jan 04, 2023 1:53 pm
Hi Bill:
Sorry for the trouble. The problem this week that crashed those files I think is now hidden by the
corrections I put in, but the material of the belt is somehow wrong or failing. I will add some more diagnostics
tomorrow and we'll see where the original problem resides. It is likely the material itself. Can you tell me if the belt shows
up if you select "Wire Frame" and try to simulate it? If it does, can you click on it and try to change its material,
( even though you cant see it?).
I suspect we'll find something about that material is bad on your machine, so I will change the material type default
for belts and see what it does, I'll post when I have the corrected file uploaded.
Posted: Wed Jan 04, 2023 2:23 pm
Hi Bill :
Version 1.007B is now online, it has additional belt safeties in creation, and fault logs in that area to tell me exactly what is
failing. Try it when you wish and let me see the last 20-30 lines of the logfile, it should point me to the offending line. Its
possible the belt may show up with this change.
Posted: Wed Jan 04, 2023 5:09 pm
by BillM
Before I loaded the new version I did run the simulation that showed the pulley belt failure. When I turned on Wireframe, I was able to see an outline of the belt but could not select the belt or change it's material.
After loading the V107B, I checked out my pulley belt program and could not see the belt unless I selected Wireframe. The following Log output file is for the program with three pulleys.
I also created another 3 pulley program tand included a ball launcher. The balls bounced off the unseen belt which at least confirmed that the simulation knew the location of the belt.
As an interesting observation: The ball launcher would only launch balls when Gravity was turned on. Is this normal?
Bill Michael
Tickerlog.txt excerpt:
er\modeldatabase.cpp(119): Initializing belt data.
er\modeldatabase.cpp(227): Initializing belt motion contour.
ker\ticker\model.cpp(769): Mesh Create: belt
ker\ticker\model.cpp(792): Mesh Stage2: belt
ker\ticker\model.cpp(801): Mesh Stage 3: belt
\tekniquemanager.cpp(171): Texture 1 attempt
\tekniquemanager.cpp(173): Texture 1 complete
\tekniquemanager.cpp(192): Texture 2 complete
\tekniquemanager.cpp(197): LUT complete
ker\ticker\model.cpp(809): Mesh Stage4: belt
ker\ticker\model.cpp(811): end Mesh Create: belt
er\modeldatabase.cpp(242): Initializing belt Shader. #1
er\modeldatabase.cpp(249): Initializing belt Shader. #2
er\ticker\drawable.h(85): Instanced Object init.
\tekniquemanager.cpp(161): Instanced Binding
\tekniquemanager.cpp(166): Instanced Binding complete
er\ticker\ticker.cpp(71): Exception code: 0xe06d7363 ((null))
\ticker\graphics.cpp(305):
\tekniquemanager.cpp(227): Shade Failed
er\modeldatabase.cpp(252): Initializing belt Shader. #3
er\modeldatabase.cpp(268): Initializing belt Shader.
er\modeldatabase.cpp(278): Initializing belt constraints.
er\modeldatabase.cpp(288): Initializing belt complete.
icker\tickerview.cpp(177): Remove Objects.
er\ticker\ticker.cpp(262): Exit App.
Posted: Thu Jan 05, 2023 1:26 am
Bill:
Thanks for the log, I will analyse it and create some fixes.
Yes, I decided that without gravity launched articles would sit still, I forgot however that
it can launch things with a speed vector... so I will undo that and make them active even without gravity. Thanks for the comment.
Posted: Thu Jan 05, 2023 1:59 am
Bill:
Version 1.008B is online. Your log showed the belts were being initialized twice at creation, once as a default single entity , then properly
as an instanced entity which may be draw multiple times in the shader. Its very possible your system didn't like this, and mine was OK with it.
It also made the log read somewhat psychotically. This version proper only inits the belt once as an instanced object. The log reads more linearly now
so if this doesn't fix the trouble, I can at least see exactly where we're failing.
Thanks for that log, it led to seeing this fairly serious error on my part.
Posted: Thu Jan 05, 2023 5:12 am
by BillM
Art:
I loaded v08B. The belts still do not display but are there if I turn on Wireframe during the simulation run.
Bill
Ticker log file excerpt:
\tekniquemanager.cpp(198): LUT complete
\tekniquemanager.cpp(200): Trilinear Sampler complete
\tekniquemanager.cpp(210): Instance Shader Init
\tekniquemanager.cpp(234): Shade Failed
Posted: Thu Jan 05, 2023 7:56 am
Interesting log. Its pointing to your system refusing to maker the shader from its blob.
I ve added a few debugs so I can see where its failing. I can duplicate your error by deleting the
file PBRVertexInstancedShader.cso in the shaderbins folder. (That files does exist on your system right? )
V1.09b is online to test that theory.
In any event, this log will tell me the size of your shader blob and if its failing on its load or its creation.
Posted: Thu Jan 05, 2023 9:00 am
by BillM
I've loaded v1.09B. The results are the same. I do have the file PBRVertexInstancedShader.cso on my system.
Bill
Tickerlog excerpt:
ker\vertexshader.cpp(22): Instanced Shader loading
ker\vertexshader.cpp(28): Instanced Shader blob size: 61260
Posted: Thu Jan 05, 2023 2:51 pm
Bill:
It seems the error is coming from the DX11 subsystem in windows when I attempt to create the
instance shader on your machine. There was a guid error in instance shaders a while back. What version
of windows is this and what is your video card type? It will allow me to investigate why a system might reject a
call to this type of shader.
As we get more feedback I can determine if this is systemic, or some esoteric code call that only some
systems hate or like. I use a rdx2070S as my card and its rather powerful compared to may older cards,
so I'm hoping it isn't a card issue. It may be a driver issue if you haven't updated the video driver in
some time.
Thanks for the tests,
Posted: Thu Jan 05, 2023 4:30 pm
by BillM
My Computer has an Intel Core7 11th generation processor, 2.68GHz. The computer has 16Gbytes of memory and 32Gbytes of virtual memory.
The Video system is an Intel iRISx Max Graphics card. This evening I downloaded updated drivers for the card.
I re-ran Ticker with pulleys but the belt still did not display.
Bill
Posted: Fri Jan 06, 2023 12:52 am
Thanks Bill:
Thats plenty of power. The next version will record the actual error codes from the DX subsystem, so that may lead me
to a solution. Ill try to make it out by tomorrow.
Posted: Fri Jan 06, 2023 1:12 am
Bill:
Version 1.10b is online and should show me exactly what the system error code is that is failing the shader. This should allow
me to get my teeth deeper into the culprit. We're very close I think, I kinda feel it will be something stupid on my part as a
missing support file or something. Ticker is video game tech really, its written in the same way as a video game but attached to
an application interface, so its a bit of a strange marriage as far as timing relationships in the code. As this is my first "Video game"
type of program of this size and nature, I expect I missed something somewhere as the belts are the only item that do as they do
in terms of communication between the graphics card and the program. Its the only time I've used the video card as a computation
unit and was interesting in terms of making it work. (Thats always a dangerous sign for systemic reliability across various hardware).
Hopefully this leads to a solution finally after all this testing. Thanks to you however, the error system is now much
more robust and corrective.
Posted: Fri Jan 06, 2023 6:04 am
by BillM
I've loaded V10B. Same results of the belt not showing. I'll continue to look at my system just to make sure that I hadn't turned off some setting. I never use my computer for interactive games so I'll start exploring if there are any gaming specific options on the computer.
Bill
TickerLog excerpt:
ker\vertexshader.cpp(25): Instanced Shader loading
ker\vertexshader.cpp(32): Instanced Shader blob size: 61260
ker\vertexshader.cpp(43): Instanced Shader blob failed: -2147024809
\tekniquemanager.cpp(212): Instance Shader complete
\tekniquemanager.cpp(216): Instance Shader 2 complete
\tekniquemanager.cpp(220): pvs complete
\tekniquemanager.cpp(224): tcb
\tekniquemanager.cpp(228): mats complete
