Ticker won’t run
Ticker won’t run
I have a fresh install of Ticker on Windows 10 that doesn’t start. No error messages on screen but there are in the log file which I could not attach for some reason but the output is below. Any help would be appreciated
0000000D827DFA08Program Starts.
0000000D827D95A80000000D827D96100000000D827D92C80000000D827D93300000000D827DF9F8Setup Doc System.
0000000D827DE398Mats and Weights complete
0000000D827DE398View Loading.
0000000D827DE358Precreate View
0000000D827DE648MainFrame created.
0000000D827DE648Ribbon Loading.
0000000D827DE648Ribbon Loaded.
0000000D827DF1E8Set Render Props.
0000000D827DF1E8Create Factory Redacted.
0000000D827DF0B8Init Window - Width:1180 Height:542
0000000D827DF0B8Creating Swap Chain Call
0000000D827DECE8Creating Swap Chain
0000000D827DECE8Swap Chain Created.
0000000D827DECE8BackBuffers Complete.
0000000D827DECE8ViewPorts Set.
0000000D827DEC38Creating Backend.
0000000D827DEC38Backend OK.
0000000D827DEC38Device and context ready to fire.
0000000D827DECE8GUI DX11 initialized.
0000000D827DF0B8Window interface established
0000000D827DF0B8Intermediate GUI Initialized.
0000000D827DF0B8Dpi Awareness Set.
0000000D827DF0B8Registering Raw input devices.
0000000D827DF0B8Window Init done.
0000000D827DE178Enable DPI aware in intermediate system.
0000000D827DE178Load Fonts.
0000000D827DE178Calibrate Hud.
0000000D827DE178Clear Mesher.
0000000D827DE178Lights....
0000000D827DE178Physics Diagnostics.
0000000D827DE178Camera.....
0000000D827DE178Sphere Cam.
0000000D827DE178WorkTable.
0000000D827DE178WorkTable model.
0000000D827DDBC8Mesh Create: 0000000D827DDBC8
0000000D827DDBC8Mesh Stage2: 0000000D827DDBC8
0000000D827DDBC8Mesh Stage 3: 0000000D827DDBC8
0000000D827DB7380000000D827DB7A00000000D827DC5A8Instanced Shader blob failed: -2147024809
0000000D827DB6F80000000D827DB7600000000D827DC4F80000000D827DC4F8
0000000D827DB8F80000000D827DB9600000000D827D9F28Shade Failed
0000000D827DDBC8Mesh Stage4: 0000000D827DDBC8
0000000D827DDBC8end Mesh Create: 0000000D827DDBC8
0000000D827DE178WorkTable..
0000000D827DE178MakeSky
0000000D827DD918Mesh Create: 0000000D827DD918
0000000D827DD918Mesh Stage2: 0000000D827DD918
0000000D827DD918Mesh Stage 3: 0000000D827DD918
0000000D827DC4280000000D827DC4900000000D827DD298Instanced Shader blob failed: -2147024809
0000000D827DC3E80000000D827DC4500000000D827DD1E80000000D827DD1E8
Re: Ticker won’t run
Hi Dee:
I'll analyse and get back to you..
I just uploaded a new version ( same version number) that expands the errors in that section a bit. Can you try it and let me know what it says?
So far, the problem appears to be your video card rejecting the main vertex shader. I have no other reports of that happenign as of yet, can you let me know what video card this is?
I downloaded and reinstalled the Windows 10 msi. Tried to open ticker and below is the content of the log file. It looks pretty much the same to me, have I got the right version?
Also the graphics card is an old HP laptop one intel hd graphics 3000. All the latest drivers are install and all the levels of acceleration are enabled. I am also using the up to date version 12 direct x
Darren
0000001A62CFF788Program Starts.
0000001A62CF93280000001A62CF93900000001A62CF90480000001A62CF90B00000001A62CFF778Setup Doc System.
0000001A62CFE118Mats and Weights complete
0000001A62CFE118View Loading.
0000001A62CFE0D8Precreate View
0000001A62CFE3C8MainFrame created.
0000001A62CFE3C8Ribbon Loading.
0000001A62CFE3C8Ribbon Loaded.
0000001A62CFEF68Set Render Props.
0000001A62CFEF68Create Factory Redacted.
0000001A62CFEE38Init Window - Width:1180 Height:542
0000001A62CFEE38Creating Swap Chain Call
0000001A62CFEA68Creating Swap Chain
0000001A62CFEA68Swap Chain Created.
0000001A62CFEA68BackBuffers Complete.
0000001A62CFEA68ViewPorts Set.
0000001A62CFE9B8Creating Backend.
0000001A62CFE9B8Backend OK.
0000001A62CFE9B8Device and context ready to fire.
0000001A62CFEA68GUI DX11 initialized.
0000001A62CFEE38Window interface established
0000001A62CFEE38Intermediate GUI Initialized.
0000001A62CFEE38Dpi Awareness Set.
0000001A62CFEE38Registering Raw input devices.
0000001A62CFEE38Window Init done.
0000001A62CFDEF8Enable DPI aware in intermediate system.
0000001A62CFDEF8Load Fonts.
0000001A62CFDEF8Calibrate Hud.
0000001A62CFDEF8Clear Mesher.
0000001A62CFDEF8Lights....
0000001A62CFDEF8Physics Diagnostics.
0000001A62CFDEF8Camera.....
0000001A62CFDEF8Sphere Cam.
0000001A62CFDEF8WorkTable.
0000001A62CFDEF8WorkTable model.
0000001A62CFD948Mesh Create: 0000001A62CFD948
0000001A62CFD948Mesh Stage2: 0000001A62CFD948
0000001A62CFD948Mesh Stage 3: 0000001A62CFD948
0000001A62CFC498Material lambertian:
0000001A62CFC498Constant Buffer:
0000001A62CFC498Texture Buffer:
0000001A62CFC498Vertex Shader:
0000001A62CFB2F80000001A62CFB3600000001A62CFC168Instanced Shader blob failed: -2147024809
0000001A62CFB2B80000001A62CFB3200000001A62CFC0B80000001A62CFC0B8
0000001A62CFB4B80000001A62CFB5200000001A62CF9AE8Shade Failed
0000001A62CFD948Mesh Stage4: 0000001A62CFD948
0000001A62CFD948end Mesh Create: 0000001A62CFD948
0000001A62CFDEF8WorkTable..
0000001A62CFDEF8MakeSky
0000001A62CFD698Mesh Create: 0000001A62CFD698
0000001A62CFD698Mesh Stage2: 0000001A62CFD698
0000001A62CFD698Mesh Stage 3: 0000001A62CFD698
0000001A62CFC1A80000001A62CFC2100000001A62CFD018Instanced Shader blob failed: -2147024809
0000001A62CFC1680000001A62CFC1D00000001A62CFCF680000001A62CFCF68
Darren
Hi :
Thanks, it did update, more error granularity, your error points to the PBRVertextShader.cso not loading properly with an error of Invalid_Argument.
This error I think is due to the graphics card not being able to properly run 5.0 shaders in DirectX. I'm searching for a solution that
would confirm this, though I dont think Ill be able to find one that solves it. I suspect highly DirectX12 is required, even though the code
is mostly based on Dx11. Ill repost if I can find supporting evidence of this, my wifes old HP system runs it fine, but it may have higher capabilities,
Ill check on that.
Ill check on that.
Sorry, but it seems the HP 3000 graphics card will only support shader model 3.0, so its a bit behind on the model required for
Ticker.
Ticker.
Thanks for checking.
Looks like I need to start thinking about a newer laptop.
Regards
Darren
Regards
Darren
Hi Darren:
I feel your pain, I'm just upgrading my wifes hp this xmas as well.
On the plus side you can have Windows 11 before W10 goes poof. My 2016 i5-5200u laptop, and i5-6500 desktop will be suffering the same fate, some days I think it's an evil plan to keep the chip makers chipping along as I'm forced to chip in for new chips
