Out of memory error when copying script to GCode
Posted: Tue May 24, 2016 4:53 am
				If a script in "MultiLine-MDI" has an unknown/undefined function and is copied to GCode tab using the  menu "MDI-Multi to GCode", "Out of memory" error pops up.
Task Manager can be used to close Auggie (or holding ESC key down).
Steps to replicate error:
1) Enter this code into MultiLine-MDI.
2) Use file menu "MDI-Multi to GCode".
3) Switch to GCode panel.
And the error dialog "Out of memory" blocks further actions.
Code in GCode panel:
Code: Select all
1 { // Script with unknown function
2   unknown();
3 }
4
Code: Select all
  unknown();
