Auggie error 7871
Posted: Sat Oct 17, 2020 8:24 pm
Hello everyone .
I modify a extension for Inlscape to generate a GCODE for cuting and engrave text or other stuffs
by colors. Well ... today i run in some problems .
Testing the extension and generate different codes to see how that work i got the Auggie error
with exasperation code 7871 , aparently the Auggie stop in the same point of the code .
If i try to run again the Auggie block in that error.
I dont realy know where is the problem . First of all i try to connect directly on PC ,
change the router config (i use one router only for Auggie ) and on the end
i say to try other codes . On any code Auggie run just fine . Only on that code .
Also i generate the GCODE with a old inkscape extension , same problem , Auggie stop in same point .
Can anyone to test the codes please ? Is not a issue but i want to understand what happen and why.
Bobby
Bobby
