Today Auggie met its milestone. Here is a photo of the first 3 image augment burns... frst two were scrmabled, problem
repaired and the indian test pattern started. This was the result of a simple GCode file load, which loads the image augment
automatically. So today, about 10 months from first shovel of code, Auggie is Alive!!! Its finally what I would call a controller.
Ill start making videos and better Documentation for it now that it has proved ( to me at least) its abilities.. The
photo is cutting with 100 levels of varying power.
Auggies First burn tests..
Re: Auggies First burn tests..
Nicely done Art.. I'm hopefully a few weeks away from doing the same..
I should do some cutting then tomorrow I will give it a go
Users browsing this forum: No registered users and 24 guests
