the Good the bad and the ugly
Re: the Good the bad and the ugly
Thx Dan:
  Once I have this ticker done, Ill be back into Auggie and Ill trace it out.
DanL
Post by DanL »
I went back and look at the other codes I sent yesterday the same error repeats stack overflow, adding more files just makes no senses, I will just find what works and stick to that.
the attached file has the error in it it's the same error with all files
DanL
Post by DanL »
The toolpath being out is in part to haveing the jerk set to 5000000 I changed it to 500000 and it comes back into line, different toolpaths used, I will go back and check the ones that where out.
