Page 2 of 2
Re: Selecting Webcam
Posted: Fri Jan 08, 2016 6:13 am
by MJBoluijt
Hi, thanks for fast reaction, it is the LogitechHD Webcam C615
Yes I use Win 7 64 bit, and indeed no camera in the selection box.
Posted: Fri Jan 08, 2016 6:37 am
Hi Rien:
DO you get a message saying
"No CaptureDevices Found on your system" , or do you get no error and just an empty box?
Posted: Fri Jan 08, 2016 6:39 am
Rien:
Could you also look in the log panel tab and see if there are any messages about resolutions, that may tell me something about why the device doesn't show up..
Posted: Fri Jan 08, 2016 7:06 am
by MJBoluijt
The last message is " Select an active video device"
Posted: Fri Jan 08, 2016 7:09 am
Its odd, the log should show either the number of devices found or an error that none were..
Ill dig into it to see if I ca at least add more messages toi help track it down..
Posted: Sun Jan 10, 2016 1:20 am
by MJBoluijt
Perhaps the following info is useable for you.
I can use the Camera in Picassa also in Mach 3 Klaus video screen and in Mach 3 Tormach CNC Scan.
Regards, Rien.
Posted: Sun Jan 10, 2016 3:25 am
Rien:
Can you check the log again, are you sure there are non messages in it to resolution, the code
is written to have no choice, it will always tel me what it saw. The log tab is a tab on the properties window that never goes away. Check it for me,
I shoudl at a minimum say something like..
No CaptureDevices Found on your system."
in the log. Can you tell me the sequence in there..Is truly nothing seen?
Posted: Sun Jan 10, 2016 7:59 pm
by MJBoluijt
This is all I see in the log file;
Engine in Idle state
Item locked in place
select tool on Left or load project to begin
Initializing complete
Select and activate Video Device
Rien.
Posted: Mon Jan 11, 2016 2:38 am
Rien:
Ill put out a new version today with more messages to help me track down why your camera is being rejected,
then Ill see if I can do something about it..
Posted: Mon Jan 11, 2016 5:15 am
by MJBoluijt
This is what I see in the log file now with the newest version;
Creating Capture Device
Finding Capture Devices monikers
By the way there is no reasen for hurry.
Rien.
Posted: Mon Jan 11, 2016 6:13 am
Thx Rien:
Odd, Ill see what stopped it form progressing from there.
