Bench stand for clock makers
Re: Bench stand for clock makers
Teaser's, too! Watchmaker's lathe tailstock and mini chop saw?
Close. It's a Sherline lathe.Mooselake wrote: Teaser's, too! Watchmaker's lathe tailstock and mini chop saw?
The little chop saw is a huge improvement over the Dremel hand tool. I got a 1/16" abrasive cutoff blade for it which will outlast several tubes of the Dremel cutoff wheels. It's great for cutting brass and stainless steel for arbors and bushings.
It's the brass pawls on the Sextus winder drum that I noticed.
Kit
Kit
I was afraid that they would be too fragile if I made them out of wood so I used .250" brass and a .0625" router bit. I used the same brass for the ratchet wheel. It cut very nicely and gave a very good finish.kit wrote: It's the brass pawls on the Sextus winder drum that I noticed.
Kit
Yes, generally. It really depends on how you build the mount and how far back from the edge of the bench that you mount it. It will also depend on where on the clock the pendulum mounts. The center of my swivel base is mounted is about 12" back from the front edge of my bench. With the clock placed vertically out past the edge of the bench, I have 64" from the top of the pendulum to the floor. However, the pendulum mounts right at the top of the frame on this clock. The bottom of the clock frame in the picture is 45" above the floor.John T wrote: Wow! That's really a nice piece of work. When I have a clock on my work stand I often want to mount the pendulum and so I need a meter clearance under the clock - does your stand allow for that?
If in doubt, just make the extension arm a bit longer and / or mount the swivel base closer to the front edge of the bench so the extension arm is more towards vertical than horizontal.
Here is a pic with an old unused pendulum from an old project. It's just a bit over 39" - about 1 meter. I just hung it on a convenient spot for illustration purposes. Hopefully you can eyeball things to see if it fits your needs.
Just couldn't leave well enough alone. I added a new mounting plate option. Fewer parts, a bit simpler, and adds another degree of motion. The ZIP file is now Version 3 above.
David,
I would like a copy of the DWG files but I cannot find the download in my version of the forum.
My computer is like me, old and grumpy.
I would appreciate a link to the zip files.
Regards
Joe
Regards
Joe
Joe, if you go to the bottom of my first post, you will see a paper clip and a file name. That's the zip file. If you're still stumped, just email me at :jredburn wrote: David,
Regards
Joe
cnc AT ldrider.ca and I'll email it to you directly.
Since my last post a few month ago, a couple of things have happened. First, I've had a few direct emails from people wanting the dxf's that were getting 404 errors from the forum when they tried to download them. I was quite happy to send them and have a few short discussions on the project. Second, I've done a fairly major redesign to simply the project. And I created a short Google doc's page showing the pic's and construction details. Email me directly if you'd like the dxf's. I keep messing about with them so you will always get the most recent versions this way. And finally, please be sure to tell me how your build goes and what, if any, suggestions that you might have to make it better. It's been a fun project.
https://docs.google.com/document/d/1F-HAzAgnLTVrnkFneN44cdpqDRKENRrmS7XUokkemjY/edit
Nice work David.
It could be used for many different things besides clocks as well.
Mike
Mike
I'd like to suggest you consider writing an article on this for, well, I don't know who exactly -- maybe Fine Woodworking? Seems like there'd be a reasonably wide audience for this thing?
(I've just started my build, using a laser for the cutting so I'm building it up out of thinner sheets of BB ply, which is working pretty well so far. I guess we'll see when I get to the larger arm piece...)
Good Morning David
Just came across your post and your clock stand is just what I need.
I too am getting a 404 error message on your download zip file and am not having any luck on reaching you via your email address(keeps telling me to correct the email address ?)
if you would'nt mind sending me a copy of your DXF files I would really appreciate it.
jerrywi@charter.net
Thanking you in advance
Jerry
jerrywi@charter.net
Jerry
Files emailed.Jerrywi wrote: Good Morning David
jerrywi@charter.net
Jerry
Please send me pic's of your finished stand and any modifications or suggestions that may benefit future builders.
David
Thank You David, Ill be sure to send pictures of the completed project.
Thanks again
Jerry
Thanks again
Jerry
