Greetings,
I have just registered for the forum and starting to using the program.
Two quick questions,
Is it possible to have guidelines added to the gear layout / placement area ( which I guess is the "Project Screen" ?) ?
and is it possible to create a gear that has not only a collar ( which I understand how to do ) but also an outer ring as in the picture?
Thanks in advance , I'm sure I'll have many other questions.
Michael
www.carveddetails.com
gears and guidelines
Re: gears and guidelines
Im not sure what you mean by "outer ring", do you mean the way the spokes are recessed in the outer rim?
I do intend on offering the capability to do such things, but it will some time till I get there.. It will be part of a new module, which wont be written
until a few other things are complete.
I cant add guidelines per say to the project screen, though I could add ore information during the placement. At the moment,
the screen should tell you the angle from the gear your placing to the one being placed upon, and I can add uch things as the x,y coordinates if that
would help.
would help.
Yes Art,,the way there is a recess...I'll just need to wait.
The XY coordinates would be a real plus...
I purchased the program this AM.
Will I receive an email on how to make the program ligit??
email is from mezalick.com
Michael
Michael
Hi Michael:
Your license was sent a few hours agao, it may have been spam grabbed. Did you check to see if your spam folder has grabbed it. I will resend in a few moments.
Contact me direct at support@gearotic.com so i can make sure it gets to you.
Michael:
Done..
Done..
Received and installed.... ;D
All looks good..
Looking forward to using this program....
Michael
All looks good..
Michael
Users browsing this forum: No registered users and 23 guests
