Okay.
If I have a DXF files that I purchased from Clayton Boyer.
If have a have tooth count, is that all I need in Gearotic to
make comparable gears to build a clock with?
R
AutoTrain Part 2
Re: AutoTrain Part 2
Yes, when your designing a clock, its all about the ratio of one gear to the other
in tooth count, size is unimportant. Design the gears to be a size you feel you can cut,
and pick whatever decorations you like in terms of spokes..
Thank you Art.
