Laser cutting metal gears
Re: Laser cutting metal gears
Post by Dan Mauch »
I'm not sure i understand about your lathe as most lathe use the X axis as the cross slide and the Z axis as the carriage. On a lathe the C axis is parallel to the Z axis so that is why I am confused.
Eastblock wrote:
Dan Mauch wrote: That is a really cool machine. You will be able to make some really cool kinetic art pieces with that.
Thanks, I hope that will be the case. However I may end up being too busy with cutting jobs for customers that I will struggle to get some play time squeezed in.
I'd like to give the ticker mechanism a go at some point. I think it could made more compact if constructed from steel. Perhaps a kit would be of interest to this community?
I also have a CO2 laser for wood/plastic, just need a CNC lathe with C-axis and Y-axis and I'm all set (those are hideously expensive though!!)
Eastblock
Post by Eastblock »
On a CNC lathe, C-axis is indexing control of the spindle. Used when milling with live tooling in the turret. With Y-axis on the turret you can mill off-center.
https://media.machines4u.com.au/machine ... 3432.l.jpg
Eastblock
Post by Eastblock »
very sweet.. Must be a hell of a laser.
Eastblock
Post by Eastblock »
ArtF wrote: Sat Dec 24, 2022 1:48 am very sweet.. Must be a hell of a laser.
Bog standard cheapish Chinese 1kW fiber laser.
Wow, 1kw fibre eh? How long for the cut for gears like those?
I was looking at fibre lasers and wondering what that experience would be like..
