GearHeads Corner
May 21, 2013, 01:32:54 AM *
Pages: [1]
  Print
Author Topic: Rack and pinion  (Read 782 times)
Sr. Member
View Profile WWW
« on: September 09, 2010, 08:37:15 AM »
Hi All;
 I have discuss adding the ability to generate rack and pinion gearing in Gearotic Motion with Art, but was wondering how important and relevant it would be for designers to have it offered?
Logged
John S
Administrator
Full Member
Nottingham, England
View Profile
« Reply #1 on: September 12, 2010, 07:03:06 AM »
Well pinions are covered and the rack is just a straight sided gear of infinite PCD.
I think the question needs to be asked how would someone want / need to cut a rack ?
If it's from a top view, rack on it's side for EDM or end milling with small cutters then this is easily laid out in any simple CAD program, draw a tooth copy offset X times.
Not knowing how the program works would it be possible to create / store one tooth in a user defined format, DP or MOD and PA then extrude this X times ? The limitatio ns are still going to be physical unless using EDM because of getting a long enough cutter to do the width of the rack, which is now defined as depth but being small enough to get into the root. Possibly creating the age old problem, drawing something that can't be machined  Shocked
Here's one I did earlier  Roll Eyes   Roll Eyes
Logged
Nottingha m, England
Sr. Member
View Profile WWW
« Reply #2 on: September 12, 2010, 11:46:08 PM »
Hi John;
 Thanks for the input. Nice work btw...I agree drawing something you can't cut is an issue and will always exist, but if it could be cut, wouldn't it be awesome? Rack's are just another one of these cases in my opinion which have many applicati ons and work very well but not so easy to come up with for most. Adding this feature could be just another one of those tools which could come in very handy at times. What if you were able to set a max cut size parameter within GM, let's say of your cnc or jig tool, then cut the rack in multiple peices using these limits to join them all togther which would eventuall y allow your final rack lenght? A simple dxf output could do I think. The issue of "long enough cutter" to cut rack may also be reduced if both tooth depth and size is known prior to generate rack and pinion, since rack and gear would be generated perfectly in GM. Anyway justa thought.. .
Logged
John S
Administrator
Full Member
Nottingham, England
View Profile
« Reply #3 on: September 13, 2010, 05:05:13 PM »
Interesti ng concept.
I tried doing a 1,000 tooth gear running with a 15 tooth pinion, the idea being that a rack is a gear of infinite diameter.
Well it barfed  Tongue I think a 1000 is too many
Logged
Sr. Member
View Profile WWW
« Reply #4 on: September 14, 2010, 07:25:31 AM »
Hi John;
 Interesti ng thing is rack is a simple straight lines to cut to make tooth ,unlike gears.
Logged
Administrator
Hero Member
View Profile
« Reply #5 on: September 24, 2010, 08:54:22 AM »
 Some examples of the 45 degree helicals. .
Logged
Thanks, have fun,
Sr. Member
View Profile WWW
« Reply #6 on: September 24, 2010, 08:55:53 AM »
Art;
 Any pictures of the "U" shapes gears?
Logged
kimvellore
Newbie
View Profile
« Reply #7 on: December 28, 2010, 12:20:45 AM »
I have applicati ons to use some rack and pinion gears, please consider it to add to the list of things to do in GM.
Kim
Logged
Sr. Member
View Profile WWW
« Reply #8 on: December 28, 2010, 12:23:16 AM »
Hi Kim;
 Noted and on the list of future possibili ties.
Logged
danmauch
Jr. Member
View Profile
« Reply #9 on: December 28, 2010, 10:17:12 AM »
 If you need it now you may want to try this. Create the spur gear that you plan to use. Then save it as a dxf file. Load the spur gear gear into a CAD program. I used Bobcad 21. Carefully select one tooth and one root. Delete the rest of the teeth and roots.  Then deterime the length by using the dimension ing feature of your CAD program. Select the tooth and root then in translate and increment s list the number of copies with the distance previousl y noted and then enter. You should then see all the teeth and roots lined up and then you should be able to create your G code from there.
www.camtr onics-cnc.com
low cost cases for gecko products.
Kits and assembled stepper and servo systems.
Kim
Logged
John S
Administrator
Full Member
Nottingham, England
View Profile
« Reply #10 on: December 28, 2010, 10:25:49 AM »
Dan surely that will use the tooth shape as the shape of the rack ?
A rack is easy to draw, it's just straight sided with an included angle of twice the PA of the gear.
Logged
David Edwards
Newbie
View Profile
« Reply #11 on: October 22, 2011, 10:20:37 AM »
This feature would be particula rly nice if it could produce racks for non-circular gears, elliptica ls, imaginari es, etc.
Logged
Sr. Member
View Profile WWW
« Reply #12 on: October 22, 2011, 10:47:14 AM »
David;
 The primary focus at the moment is set on clocks. I know there was some talk for racks in future but not sure when that will materiali ze at this point, especiall y for elliptica l's and imaginary . Thanks for posting your idea.
Bob  Smiley
Logged
Administrator
Hero Member
View Profile
« Reply #13 on: October 22, 2011, 10:53:20 AM »
   A rack is possible for a noncirclu lar, but it would look very strange and the elliptica l or noncircul ar gear would only fit it a particula r angle
to start. Each tooth in a rack for a non-circular woudl be different as opposed to a spur which is simply as John explained, a PA angle to to tip on each tooth.
Logged
Thanks, have fun,
Pages: [1]
  Print
Jump to:
