GearHeads Corner
May 23, 2013, 06:59:24 PM *
Pages: [1]
  Print
Author Topic: Shaft Diameter on Ratchets  (Read 192 times)
Full Member
View Profile WWW
« on: May 07, 2012, 12:22:44 AM »
For some reason the shaft diameter can't be changed if I'm working on a ratchet.  If I go the the spur gears everythin g is fine but I can't get the diameter to change to what I want on the ratchet.
Is it just me?
Logged
1% inspirati on 99% try, try again
Administrator
Hero Member
View Profile
« Reply #1 on: May 07, 2012, 06:43:24 AM »
  Ooops, my fault. Ill issue a fix shortly. It was due to changes in the escapemen ts code..
Logged
Thanks, have fun,
Full Member
View Profile WWW
« Reply #2 on: May 07, 2012, 02:12:45 PM »
I've downloade d 4.66 - thanks for the quick action.  The shaft diameter changes work well in the default project however when I go small in producing  a ratchet I still have a problem.
The little ratchet I'm producing is 1" outside diameter which with 6 teeth and a 6 pitch is what I want.  Then I need a 0.375" shaft and it won't generate (relativel y a huge shaft).  Here is the code I've produced.
Perhaps I've just exceeded the limits of the program?
* LittleRatchet.gprj (0.13 KB - downloaded 6 times.)
Logged
Administrator
Hero Member
View Profile
« Reply #3 on: May 07, 2012, 02:48:47 PM »
   You did exceed it. If you redownloa d youll find you no longer do. Ive relaxed the autoinhib it for shaft size, so give it a shot now, but
be carefull the shaft isnt larger than the gear. Smiley
Logged
Thanks, have fun,
Full Member
View Profile WWW
« Reply #4 on: May 07, 2012, 07:02:09 PM »
Many thanks - it works for me now.
The photo shows what I made - a 6 tooth 1 inch ratchet with a 3/8" shaft.  I used three shear pins to hold it to the wind drum.
Thanks again
Logged
Administrator
Hero Member
View Profile
« Reply #5 on: May 08, 2012, 07:19:20 AM »
Smiley
 Excellent ..
Logged
Thanks, have fun,
Pages: [1]
  Print
Jump to:
