GearHeads Corner
May 21, 2013, 04:53:41 AM *
Pages: [1]
  Print
Author Topic: Save and print  (Read 300 times)
John S
Administrator
Full Member
View Profile
« on: March 18, 2012, 07:11:51 AM »
Probably me, come to save a series of layouts and first one is 19 teeth and 29 teeth in 8DP.
Save as 19_29 grp whatever and then close, go back open it and it's the default 5DP file ?
Perhaps this cannot save gears only the project ?
Also only works once, save the second time over writes the first example, you have to close, redo the layout then save. really needs save As ?
Print.
Be nice to have a print button so you can print the gear data screen. At the moment I'm going Alt print Screen then into Ifranview, then print.
John S
Logged
Nottingha m, England
Administrator
Hero Member
View Profile
« Reply #1 on: March 18, 2012, 08:08:43 AM »
  There is a bit of fudging in the save option. Some of it is the result of that damn framework not working as it should. Doc's on MFC Feature pack are terrible.
Wish Id never used it really.. Ill look into a print feature for gear data. When you load a file the DP of the design screen does default back to 5.. but selecting a
saved gear adn pressing "Send to design" shoudl update the design page with appropria te informati on.
Logged
Thanks, have fun,
Sr. Member
View Profile WWW
« Reply #2 on: March 18, 2012, 12:48:08 PM »
John;
 I customize d my toolbar in Gearotic to include the "Save As" button. I did this by selecting the  "customize quick access toobar" (top right), more commands, then added the save as feature. Worked for me anyway..
Bob  Wink
Logged
John S
Administrator
Full Member
View Profile
« Reply #3 on: March 18, 2012, 02:24:58 PM »
Damn,
Looked in there and missed the save as button.
You sure you have not just added it to make me look an ijit ? [ mind you that's not hard ]
Logged
Administrator
Hero Member
View Profile
« Reply #4 on: March 18, 2012, 02:37:03 PM »
  Smiley No, buts annoying, it wont stay onscreen, you have to turn that on each time.. Ill fix that up..
Logged
Thanks, have fun,
Pages: [1]
  Print
Jump to:
