GearHeads Corner
June 19, 2013, 03:16:34 PM *
Pages: [1]
  Print
Author Topic: 3D d print of a Helical gear  (Read 524 times)
danmauch
Jr. Member
View Profile
« on: March 04, 2012, 12:57:44 PM »
 Using GM, Mach3, slicer program, a G540 and my retrofitt ed cnc machine with a ABS extruder.
http://www.youtube.com/watch?v=ua2k-kH601M&feature=youtu.be
Camtronic s Inc
Logged
Bloy
Newbie
Wave goes here :)
View Profile
« Reply #1 on: March 04, 2012, 01:29:05 PM »
I'll be checking back in a few minutes.. ..as youtube has instructe d me to do.  Smiley
Logged
John M
Sturgeon Bay, WI
danmauch
Jr. Member
View Profile
« Reply #2 on: March 04, 2012, 04:30:26 PM »
This is the correct  link. http://www.youtube.com/watch?v=Yr_Bt04j88s&feature=youtu.be
dan
Logged
Administrator
Hero Member
View Profile
« Reply #3 on: March 04, 2012, 05:26:09 PM »
wow, much faster than I thought it would be..
Logged
Thanks, have fun,
Sr. Member
View Profile WWW
« Reply #4 on: March 04, 2012, 11:26:58 PM »
Awesome Dan, much better speed than I expected also..Ver y impressiv e..
Bob Smiley
Logged
Bloy
Newbie
Wave goes here :)
View Profile
« Reply #5 on: March 05, 2012, 12:17:59 AM »
Ditto..Aw esome!  That's an interesti ng asteroida l nozzle. I'm guessing has to do with temperatu re control. It looks like insulatio n used to contain the heat for accurate sensing.
« Last Edit: March 05, 2012, 08:50:00 AM by Bloy » Logged
John M
Sturgeon Bay, WI
danmauch
Jr. Member
View Profile
« Reply #6 on: March 05, 2012, 10:22:30 AM »
I can increase the speed quite a bit. Right now I Have Mach3 velocity set at 900 but previousl y had it up to 1200. I tuned it back when I figured out that the calibrati on of the filamnet flow rate was incorrect . Now that I have calibrate d the extruder I need to go back and raise the axis velocity back up.
I think I can also go into Slic3r and increase the speed that it sets for the Gcode.
Logged
danmauch
Jr. Member
View Profile
« Reply #7 on: March 05, 2012, 10:30:37 AM »
 I read on the GenXlab blog about using your cnc machine as a 3d printer  that they recommend ed the Maker Gear stepper plastrude r. They said it was bullet proof . So far i have used a couple hundred feet of abs filament and found their recommend ation to be accurate. The heated element does have an insulatin g compound around .37mm  the noozle where a thermocou ple is embeded. That if followed by kapton tape and then two fiberglas s insulatio n boots. Work great.
Logged
Pages: [1]
  Print
Jump to:
