GearHeads Corner
May 25, 2013, 05:44:13 AM *
Pages: [1]
  Print
Author Topic: BEX event error on 2D output  (Read 145 times)
Brian Decker
Newbie
View Profile
« on: February 03, 2012, 04:58:29 PM »
Tried to work around this a number of ways but have not found one that works - tried turning off DEP, compatibi lity modes, etc. all to no avail. I can get 3d output but no 2d output without an immediate BEX error.  I installed an older version of GM on an external drive and received the same error.  Any thoughts?
Logged
"If you don't bleed on it, how do you prove that it is yours?"
Administrator
Hero Member
View Profile
« Reply #1 on: February 04, 2012, 12:29:14 AM »
Whats a BEX error? Im not familiar with it. Have you tried running as admin in the programs context menu?
ARt
Logged
Thanks, have fun,
Brian Decker
Newbie
View Profile
« Reply #2 on: February 04, 2012, 06:59:40 AM »
BEX events occur when the buffer overflows and the Win7 DEP steps in and stops the program.  I am receiving the error on my laptop and desktop (both quad-core win7 machines with tons of RAM) so I'm guessing it is an issue with GM and win7.  I'll keep playing around with it and see what I find.
Logged
Administrator
Hero Member
View Profile
« Reply #3 on: February 04, 2012, 11:03:43 AM »
Hi Brian:
  Ive never seen a BEX error, the only issue with Win7, is that SGCore uses a font call that requires the
progrm to be run with right-click/run as admin in order to properly administe r the font access. Are you running in Admin mode?
 A web search shows me BEX errors, but usually in the context of some other program, this is the first Ive heard of an error of that type,
it may be related to some other software running.. thats typical when a user gets it on multiple machines as that person tends to have similar software on all machines. Let me know if you see anything that can help me track it down for you.
Logged
Thanks, have fun,
Brian Decker
Newbie
View Profile
« Reply #4 on: February 04, 2012, 02:02:06 PM »
I tried tried running as admin with no change - when I start to export a 2d file the blue bar moves about 1/4 distance and then I get the "program has stopped working" dialogue box with this descripti on-
Problem signature:
  Problem Event Name:   BEX
  Applicati on Name:   GearoticM otion.exe
  Applicati on Version:   1.0.0.1
  Applicati on Timestamp:   4f076e6c
  Fault Module Name:   GearoticM otion.exe
  Fault Module Version:   1.0.0.1
  Fault Module Timestamp:   4f076e6c
  Exception Offset:   0019fdae
  Exception Code:   c0000417
  Exception Data:   00000000
  OS Version:   6.1.7601. 2.1.0.256 .1
  Locale ID:   1033
  Additiona l Informati on 1:   c165
  Additiona l Informati on 2:   c165d7ebf 346e73e7f 2a0bb4543 21fc4
  Additiona l Informati on 3:   ef44
  Additiona l Informati on 4:   ef445d74e 91e081ae6 f50f22fb4 14875
I'll keep troublesh ooting this end-  the main reason this is an issue is that I only have the 2d version of PartWorks and the 3d dxf (which do export) seems to have problems with the 3d dxfs.
Logged
Administrator
Hero Member
View Profile
« Reply #5 on: February 04, 2012, 03:09:44 PM »
I did some searching, and it seems to be OS or hardware related. I guess Im lucky not to have seen it before.. Ill keep my fingers crossed you can find something ..
Logged
Thanks, have fun,
Pages: [1]
  Print
Jump to:
