GearHeads Corner
May 20, 2013, 12:51:48 PM *
Pages: [1]
  Print
Author Topic: escapement wheel design  (Read 273 times)
Tak
Newbie
View Profile
« on: January 22, 2012, 06:11:50 PM »
Hi,everyone
I started my first project making a gear clock with GM.
So far I have cut all the gears except escapemen t wheel.
The escapemen t wheel has 60 teeth and I set module 3.0 which makes the wheel diameter 180mm.
I tried to cut this few times on my cnc router with different settings but no success.
Simply the teeth is too fine for the plywood.
I tried to set the parameter s to change the shape to make the teeth good enough for cutting out of plywood.
So far I couldn't get the shape I wanted.
Is any solution for this?
PS sorry for my bloody English as I grown up in non English backgroun d.
Logged
Administrator
Hero Member
View Profile
« Reply #1 on: January 22, 2012, 11:41:26 PM »
  Try increasin g your witness ratio on the screen. It makes the teeth thicker.. Also, if using plywood, make sure its russian birch, its the only plywood I know of with no internal gaps that make small plywood teeth break..
Logged
Thanks, have fun,
Brian Decker
Newbie
View Profile
« Reply #2 on: January 23, 2012, 06:37:10 AM »
Agree 100% with Art - I've got 4 of the GM escapemen ts running now and they are all 3/8ths Baltic Birch.  The teeth are holding up fine - though I think for a long-lasting clock some thought needs to be given to the going train so the teeth are not bearing too much force.
Logged
"If you don't bleed on it, how do you prove that it is yours?"
Tak
Newbie
View Profile
« Reply #3 on: January 23, 2012, 09:57:09 PM »
Thanks Art
I'll try and come back later.
Hi Brian
Would you mind sharing your parameter of the escapemen t wheel setting please.
Logged
Brian Decker
Newbie
View Profile
« Reply #4 on: January 24, 2012, 06:37:52 AM »
Sure - it's basically the stock setting with the shafts changed to 1/2" -
MOD: 6.3500  DP: 4.00 Teeth: 30.00 Pressure Angle: 20.00
Pitch Diam: 7.5000  Outside Radius: 3.7500
Cycloidic: 0  Shift: 0.00 Stubbing: 1.00 Width: 0.50
Logged
Tak
Newbie
View Profile
« Reply #5 on: January 24, 2012, 04:47:04 PM »
Thanks Brian
I'll try yours first.
Logged
Pages: [1]
  Print
Jump to:
