GearHeads Corner
May 18, 2013, 08:01:07 AM *
Pages: [1]
  Print
Author Topic: Some recent clocks from my shop  (Read 349 times)
Brian Decker
Newbie
View Profile
« on: January 21, 2012, 03:46:43 PM »
Not sure how intereste d anyone will be but it never hurts to share what projects we have going Grin  These clocks have brass movements built from kits - my focus now is on developin g a tradition al wood gear movement to go into a long case style clock.  There was a gentleman named Luman Watson who was among the first clockmake rs here in Cincinnat i in the early 1800's and I am inspired by his work.  He was the first to show that even with a wood gear movement it was possible to build an accurate, beautiful and reliable clock.
Carved "coffin" clock:
Skeleton table clock:
Wall clocks:
Logged
"If you don't bleed on it, how do you prove that it is yours?"
Administrator
Hero Member
View Profile
« Reply #1 on: January 21, 2012, 04:26:04 PM »
You sir, are a craftsman ...
Logged
Thanks, have fun,
Full Member
View Profile
« Reply #2 on: January 21, 2012, 05:41:00 PM »
Amazing!  The celtic art is impressiv e.
Did you do all this by hand?
Logged
Brian Decker
Newbie
View Profile
« Reply #3 on: January 21, 2012, 06:11:03 PM »
Quote
This is one of those sticky questions that often devolve into flame wars on the woodworki ng forums Shocked
Most of the woodworke rs I know have some subjectiv e level of tools that qualify as "ok" or "not ok" to use - I think they are all arbitrary .  I've a great friend who makes amazing furniture in a shop that could be right out of the 1800's - other than some seriously large planers and tablesaws he uses to rough out his own lumber.  Everythin g else is literally "done by hand".  My shop is on the other end of the spectrum - I think the lights in the neighborh ood probably flicker when I'm in my shop Grin  Other than finish sanding and measuring I can't say I do much with hand tools.  I'm not sure if either of us is any less a woodworke r - we just use different tools and technique s to get there.
The carvings are initially cut with my shopbot - but that is only the first step.  There is a great deal of finishing work and sanding required to actually finish the carvings after they come off the bot.  The inside cuts of the Triqueta cutouts are especiall y time consuming as the best method I've come up with is to "shoeshine" the inner faces with strips of sandpaper .  For my shop it just comes down to time and efficienc y - if I were to carve everythin g by hand I'd lose so much money to time I'd never make any money.
Logged
dansfoundry
Newbie
View Profile WWW
« Reply #4 on: January 21, 2012, 08:24:35 PM »
Brian very nice work. I think you are preaching to the choir so to speak. I use to make things by hand because it was the only thing available . Nobody can afford what I did by hand even when I only charged two dollars an hour Grin I have welcomed technolog y with open arms. Even if you have all the gadgets in the world you still need a sense of design and you have that. Dan
Logged
Sr. Member
View Profile WWW
« Reply #5 on: January 21, 2012, 09:29:40 PM »
Brian;
 I'd say your technique is working out just fine, keep paying the electric bill, it is obvious you'll be fine.
 Nice work.
Logged
Ken_Shea
Jr. Member
View Profile
« Reply #6 on: January 22, 2012, 07:40:06 PM »
That's some seriously nice work, Brian.
Love the little skeleton table clock.
Ken
Logged
Pages: [1]
  Print
Jump to:
