GearHeads Corner
May 21, 2013, 03:10:33 PM
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
GearHeads Corner
General Category
Gear Discussions
moving a gear around in the project ctrl screen
Pages: [
1
« previous
next »
Print
Author
Topic: moving a gear around in the project ctrl screen (Read 164 times)
Tak
Newbie
on:
January 19, 2012, 06:18:40 PM »
Hi, I'm newbie to this forum,
I just purchased the program and I'm trying to work out how to use this program.
Here's my first question.
How to move the gear that already engaged to the another one in the project Ctrl screen?
Tak
Logged
Administrator
Hero Member
Re: moving a gear around in the project ctrl screen
Reply #1 on:
January 19, 2012, 07:06:48 PM »
Hi Tak:
You can not do that. You CAN delete a gear, and replace it by right clicking on the gear in the tree and selecting delete..b
ut all gears forward from that gear will also go away. When you build a mechanism, each gear you place bcomes locked and is set to that position unless deleted, and since all following gears depend on that gear being that size and position, all forward gears delete with it.
Logged
Thanks, have fun,
Brian Decker
Newbie
Reply #2 on:
January 19, 2012, 09:17:34 PM »
I ran into this a few times - and at first I thought it was a negative. However - since as is pointed out changing one gear will affect all the subsequen
t gears and shafts it is a good approach.
Logged
"If you don't bleed on it, how do you prove that it is yours?"
Administrator
Hero Member
Reply #3 on:
January 19, 2012, 09:36:19 PM »
Brian:
Thx. The main reason it cant be done is that to do so woudl require me to ask dozens of questions about recenteri
ng, remeshing
..etc.. Once that pandora's box of options
would be opened, GM woudl start to be a lot more complex to use than it is. I try to keep it simple, that has limitatio
ns, but their usually worth it.
Logged
Thanks, have fun,
Pages: [
1
Print
« previous
next »
Jump to:
Please select a destination:
To Join Forum, please email Support@gearotic.com
=> To Join This group, please email support@gearotic.com
General Category
=> Newest Rev Release
=> Bevel Machining Discussions
=> Registered Users
=> Gear Discussions
=> Support and Bug Reports
=> Suggestions for Future
=> Third Party Software
=> 3d Printers Discussion
=> Conventional Gear Cutting forum
=> Contest Entries
=> 3D Printer Examples
User Video Links
=> User Photo's ( Show anfd Tell)
=> Your Videos
Loading...
