GearHeads Corner
May 24, 2013, 12:42:52 AM *
Pages: [1]
  Print
Author Topic: Version 4.29 online  (Read 435 times)
Administrator
Hero Member
View Profile
« on: January 16, 2012, 09:43:38 PM »
   This is a temp release while I work out a few issues. It will give you the chance to play some with knuckle gears,
and or helicals in their new format. 3d-dxf's or stl's may be put out for either type. To make a knuckle, try making a
helical, and select the knuckle override when you create them.
  Just to reiterate, a knuckle is full-knuckle if its set to 45 degree's. A 22.5 is half knuckled. .etc.. Knuckles must be created
left/right handed to mesh. However, this is only a simulatio n limit, in reality a left handed when flipped over becomes a rigth handed
so meshing any two knuckles will work..pro vided they are of the same degree, and the same gear face width. Since the knuckle is an
arc placed on the tooth face width, the widths must always match.
 Let me know your experienc es, I likely have some cleanup to do. Smiley
Logged
Thanks, have fun,
Full Member
View Profile WWW
« Reply #1 on: January 17, 2012, 01:52:36 PM »
I don't use the knuckle part but I appreciat e the fix on the foam spokes they work - Thanks.
Logged
1% inspirati on 99% try, try again
Full Member
View Profile
« Reply #2 on: January 17, 2012, 02:17:57 PM »
Nice picture!
Do carbide endmills make good shafts for gears?  Did you use bushings?  It could be a good use for that box of busted bits, and they should wear well...
Logged
Full Member
View Profile WWW
« Reply #3 on: January 17, 2012, 02:53:46 PM »
Hi Kirk,
Exactly right I use broken carbide bits as the shafts and no bushings - they are just things to fidget with.
Logged
DesertRunner
Newbie
View Profile
« Reply #4 on: January 18, 2012, 09:28:07 PM »
Have had to appeal to the IT guys because the the update is being booted out for the following isse.
Clamd: Heuristic s.Broken. Executabl e
Tony
Logged
Administrator
Hero Member
View Profile
« Reply #5 on: January 18, 2012, 10:06:38 PM »
I wonder what the heck a broken heuristic is...
Logged
Thanks, have fun,
DesertRunner
Newbie
View Profile
« Reply #6 on: January 19, 2012, 12:07:36 AM »
Hi Art, its all good now the IT guy allowed you software and I am all happy.
The mods look great its a bit easier to understan d what you are doing when what you see is what you get.
Thanks for the great work.
Tony
Logged
Pages: [1]
  Print
Jump to:
