GearHeads Corner
May 24, 2013, 02:34:59 AM *
Pages: [1] 2
  Print
Author Topic: Using Lantern Gages with Cycloidal Gears  (Read 804 times)
Ken Condal
Newbie
View Profile
« on: December 22, 2011, 08:15:35 AM »
I'm doing a design that requires a small lantern cage to mesh with a cycloidal gear. I've set the pin diameter to the proper size for these to mesh, but GM won't let me assemble them on the Project Panel. It just says Wrong Gear Type. Can you relax your error checking a bit, or is it more complicat ed?
Ken
Logged
Administrator
Hero Member
View Profile
« Reply #1 on: December 22, 2011, 10:37:05 AM »
Ken:
  Its a bit more complex than that as some of the informati on doesnt match between the two types. I have relaxed the rules for you though to allow the meshing in the meantime, though the simulatio n may overlap for some gears. Ill fix that up over time, btu at least
youll be able to make them appear in simulatio n and the centering will be OK and such for final outputs.
Logged
Thanks, have fun,
Ken Condal
Newbie
View Profile
« Reply #2 on: December 29, 2011, 09:22:33 AM »
This feature now works in 4.25 but only partially . It seems that if I add the cage first I can then add an Epy gear to mesh with it. However, in my project, I need to add the Epy gear BEFORE the cage to get the proper placement . In that case I still get the "Wrong Tooth Type" message.
Am I doing something wrong or is there a workaroun d?
Ken
Logged
Administrator
Hero Member
View Profile
« Reply #3 on: December 29, 2011, 02:17:27 PM »
Ken:
 Another oopps. Sorry I fixed so much up that a couepl bugs crept in.. Ill fix that for tonights release as well.
Thx\
Logged
Thanks, have fun,
Administrator
Hero Member
View Profile
« Reply #4 on: December 29, 2011, 02:27:10 PM »
Ken:
  Hmm, just ch3ecked. . I can place cage..the n epi.. or epi, then cage..
Can you send me a project file that you cannot add a cage gear to?
Logged
Thanks, have fun,
Ken Condal
Newbie
View Profile
« Reply #5 on: December 29, 2011, 06:25:11 PM »
I'm starting with a New project. I create an Epy 147T gear with a DP of 31.75 (.8 Mod) and add it as the first gear in my project. Then I go to the Lantern panel and create an 11T cage and a 147T pinion. I press Create Wheel (the cage) and click on the existing 147T Epy when it turns red in the project window. I get a beep and "Wrong Tooth Type".
Ken
Logged
Sr. Member
View Profile WWW
« Reply #6 on: December 29, 2011, 09:53:34 PM »
Ken;
 Your right, an error does present itself, I get solid creation failed instead and I can see loops in the cage teeth. Problem noted and will hopefully have a solution soon.
Bob Undecided
Logged
Administrator
Hero Member
View Profile
« Reply #7 on: December 30, 2011, 03:14:35 PM »
Hmm, could this be because the mod is different? Generally, the program hates to mesh two diffing mod's..
Logged
Thanks, have fun,
Ken Condal
Newbie
View Profile
« Reply #8 on: December 30, 2011, 09:14:49 PM »
In my testing the Mod of both gears is .8, although I'm working in inch so I set the DP to 31.75
Ken
Logged
Administrator
Hero Member
View Profile
« Reply #9 on: December 31, 2011, 11:17:35 AM »
Hi Ken:
  I see the release doesnt allow it, but my developme nt does.. SO I hopefully will get a new version out tomorrow and that shoudl fix up your trouble. Ive relaxed the meshing requireme nts with the understan ding that the teeth may not seem to mesh properly in the simulatio n, though as long as you know the result should be OK, your fine to design such a mechanism . Smiley
Logged
Thanks, have fun,
Ken Condal
Newbie
View Profile
« Reply #10 on: January 01, 2012, 08:49:45 AM »
I love it when software accepts the fact that its user may actually know what he's doing!  Grin
Happy New Year,
Ken
Logged
Administrator
Hero Member
View Profile
« Reply #11 on: January 01, 2012, 10:01:52 AM »
Ken:
  Smiley , its a delicate thing though, too much leeway and support letters bulge up, too little and its hard to use..
We'll tweak to find that balance..
Happy New Year..
Logged
Thanks, have fun,
Full Member
View Profile
« Reply #12 on: January 01, 2012, 03:34:24 PM »
Perhaps some new options - beginner with full restricti ons, advanced with more generous checks and warnings instead of errors, and one for letters to support will be ignored for the truly adventuro us.
Logged
Sr. Member
View Profile WWW
« Reply #13 on: January 01, 2012, 05:57:01 PM »
Hi Kirk;
 Good idea but too complicat ed in general to set restricti on levels I think, unless maybe the user selects the level he/she wants while using Gearotic Motion... humm...
Logged
Full Member
View Profile
« Reply #14 on: January 02, 2012, 02:31:05 AM »
Bob:
I was thinking beginner/advanced/highly creative (you're on your own) options in the settings, to vary the level of error checking from strict to very loose.  Sometimes you're having a bad typing day and need some help, sometimes you just want to do something new and exciting outside the rules.
CNC makes remakes easy, and if you're like us here in Mooselake and work in plywood you can always use some extra kindling this time of year.
Logged
Pages: [1] 2
  Print
Jump to:
