GearHeads Corner
May 21, 2013, 01:40:54 PM
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
GearHeads Corner
General Category
Gear Discussions
Very slow cutting of involute teeth
Pages: [
1
« previous
next »
Print
Author
Topic: Very slow cutting of involute teeth (Read 192 times)
allistar
Newbie
on:
October 29, 2011, 05:26:08 PM »
Hi all,
I'm cutting a simple 22 tooth spur gear (Module = 5, p angle = 20) using a 4mm flat head milling bit via EMC2. This is in 12mm MDF using 1mm deep passes each time. The hole in the middle and the spokes cut out as fast as can be expected. However, cutting the teeth themselve
s is very slow. EMC2 says the gcode should take about 20 minutes to mill. The reality is that it took about 2 hours. It's the cutting of the teeth that is painfully slow - slow enough to burn the wood.
It's milling this kind of output that is slow:
G02 X38.4770 Y10.0276 I38.0098 J8.0829
G01 X38.8059 Y9.9486
G02 X38.8451 Y9.9387 I38.3387 J8.0039
G01 X39.1862 Y9.8494
G02 X39.2252 Y9.8388 I38.6798 J7.9146
G01 X39.5784 Y9.7387
G02 X39.6106 Y9.7293 I39.0330 J7.8145
G01 X39.8526 Y9.6563
Is the a reason this is so slow, and is there anyway to speed this up? Is this a gcode output issue or is it an EMC issue?
Allistar.
Logged
dfmiller
Newbie
Re: Very slow cutting of involute teeth
Reply #1 on:
October 29, 2011, 06:08:44 PM »
Look through your code for the last F command. it stays that speed until it gets another one.
What is generatin
g the G code. Are you using the 2.5D Gcode option?
If you are you set the feedrate in the right side of the output manager.
It would seem that that is slow.
Dave
Logged
Administrator
Hero Member
Reply #2 on:
October 29, 2011, 06:21:09 PM »
If its not feedrate, try increasei
ng your point distance in the settings. The reason Point Distance exists is that some controlle
rs go very slow when a
group of small moves is in the queue. Making your point distance larger can make all the motions larger increasin
g speed on controlle
rs that do that.
For example if .001 is making it slow, set point distrance to .01 , it shoudl run much faster if the problem is the controlle
rs ability to queue motions together.
Logged
Thanks, have fun,
allistar
Newbie
Reply #3 on:
October 29, 2011, 09:48:40 PM »
It's not the feed rate. I've discovere
d that setting "G64 P.2" first makes all the differenc
e. This sets the path control mode in EMC. It may result in a less accurate output, but .2mm is accurate enough for me! The speed of cutting the teeth is now nearly 3 times as fast. I alse set the point distance to .4 (mm) which greatly reduced the number of lines of GCode to run. I'll see how this all impacts the meshing of the teeth in the final gears.
Is there a way to include hand coded Gcode into the final output from the output manager? In my case I would always get it to output "G64 P.2" first. If not, it's a good idea for a potential enhanceme
nt.
Thanks for the help,
Allistar.
Logged
Pages: [
1
Print
« previous
next »
Jump to:
Please select a destination:
To Join Forum, please email Support@gearotic.com
=> To Join This group, please email support@gearotic.com
General Category
=> Newest Rev Release
=> Bevel Machining Discussions
=> Registered Users
=> Gear Discussions
=> Support and Bug Reports
=> Suggestions for Future
=> Third Party Software
=> 3d Printers Discussion
=> Conventional Gear Cutting forum
=> Contest Entries
=> 3D Printer Examples
User Video Links
=> User Photo's ( Show anfd Tell)
=> Your Videos
Loading...
