GearHeads Corner
May 25, 2013, 05:07:31 PM *
Pages: 1 ... 5 6 [7]
  Print
Author Topic: Cutting Tool Generatin -- new name  (Read 3736 times)
philbur
Newbie
View Profile
« Reply #90 on: September 25, 2011, 11:16:47 AM »
But a small diameter end-mill rotates at much higher rpm (say at least 10 and maybe 50 times) and has more than one cutting edge (say 2 flutes). So the number of facets per minute with and end-mill is order of magnitude 20 to 100 times that of a fly cutter.
Phil:)
PS: The flycutter does cut both faces at the same time. so 10 to 50?
PPS: Maybe not so simple, the fycutter is much stronger so DOC can be higher??
« Last Edit: September 25, 2011, 11:29:43 AM by philbur » Logged
  Print
Jump to:
