GearHeads Corner
May 25, 2013, 05:51:00 PM *
Pages: [1]
  Print
Author Topic: Gear sizing question  (Read 304 times)
msimpson
Newbie
View Profile
« on: June 11, 2011, 01:05:16 AM »
OK I have a clock shown here
http://youtu.be/Ys4LtRwOrjk
Works very well.
However to get the hour and minute stacked gears to work i had to increase the size of a gear to get it to properly mesh.  I used the shift option when I created the pinion gear. I added .3 and that the gear diameter up to size so the teeth would fall where I needed them to.
Is this ok to do.  I have a clock where I have some fairly complicat ed stacked gears and on a couple of the gears I need them to mate.  I cant mess with the positioni ng, Pitch, or number of teeth so I need to lengthen or shorten the teeth so they have a better mesh.
Note that when I say stacked I am refering to one shaft inside another. IE Seconds shaft inside minutes shaft, inside hours shaft.
Logged
John S
Administrator
Full Member
View Profile
« Reply #1 on: June 11, 2011, 03:53:05 AM »
Yes that's fine, industry does this all the while.
Strip any car transmiss ion and odds are there will not be a standard gear in the whole box.
All altered for strength, quiet running etc.
Logged
Nottingha m, England
Administrator
Hero Member
View Profile
« Reply #2 on: June 11, 2011, 08:18:39 AM »
m:
  One thing you can do, is when creating gears for such mechanism s, add a small amount of standard backlash to the first gear off a mesh.. That makes the shaft that small amount shifted. The backlash setting is there for just such a problem. GM makes the math
as close to perfectio n as it can, tolerance s mean that almost any gear will be ever so slightly tight if you use the "perfect" numbers. Backlash allows you to loosen thiings ever so slightly to take tolerance s into account..
  Gears then placed between those two shafts will mesh a bit looser.. I wont say better because that depends on the situation ..
Logged
Thanks, have fun,
Administrator
Hero Member
View Profile
« Reply #3 on: June 11, 2011, 08:19:55 AM »
m:
 By the way... VERY nice clock, I like it a lot..
Logged
Thanks, have fun,
msimpson
Newbie
View Profile
« Reply #4 on: June 11, 2011, 01:37:09 PM »
I just finished a book. Its and illistrat ed guide to building the CNC I am now using for my gears.  I modeled the CNC down to every single nut and bolt so I could do exploded illistrat ions. When the web site goes public. I plan on a illistrat ed guide of that clock as well.  It will included step by step instructi ons as well as Gcode for all the parts in the clock.
I am also modeling the clock (hence the autocad questions).  It will be modeled in both Autocad and 3Ds Max.  3D modeling is easyer to do in 3ds and I can do animation s of assembly.  Autocad is better at outputtin g exploded drawings.  Autocade works better with solids and 3Ds is pretty much all Mesh.  Autocad will handle mesh as long as you arnt doing much with them.
Logged
Pages: [1]
  Print
Jump to:
