GearHeads Corner
May 19, 2013, 01:34:35 PM *
Pages: [1]
  Print
Author Topic: gCode to Mach 3  (Read 233 times)
Full Member
View Profile WWW
« on: April 19, 2011, 08:53:47 AM »
A suggestio n you might be able to do without too much effort-
When I load a .tap file into Mach3 there is a lot of informati on at the top of the gCode that tells about the variables I used to design the gear.  There is one piece of informati on missing that would really help me and that is the tool that I identifie d in GM to generate the code.  If I can't remember what tool I used to generate the design I don't think there is a way to find out from the gCode.
Logged
1% inspirati on 99% try, try again
Administrator
Hero Member
View Profile
« Reply #1 on: April 19, 2011, 09:18:15 AM »
  Consider it done. Ill put it in this weeks release.
Logged
Thanks, have fun,
Pages: [1]
  Print
Jump to:
