GearHeads Corner
May 21, 2013, 09:41:30 PM *
Pages: 1 [2]
  Print
Author Topic: My First Laser cut gears  (Read 2174 times)
Full Member
View Profile WWW
« Reply #15 on: April 19, 2011, 02:47:46 AM »
Like it!
Art, I figure you're now working on a gearbox to drive its wings Grin
Where are you getting the plans from?
Logged
Administrator
Hero Member
View Profile
« Reply #16 on: April 19, 2011, 08:38:44 AM »
LOL.. yes, its always nice to show off with a new toy.
Ive finished my exeprimen ts used to get used to it now though, and am designing a re-design of a HP1000 ink jet printer
to fit in a plexi cage that can be hung from a spindle plate to use as a usb controlle d 3d printer.
  I bought a new HP1000 ( 28.00 from walmart) ripped the guts totally out.. and am redesigni ng the printer to be what I need.
Christ knows if it will work, but its interesti ng to see if I can make this thing do what I want instead of what HP expected. Smiley
  Ill probably need some gearotic gears to make it work out as I have to move the feed motor to a new spot to create a box that
basically hangs there with the inkjet at the bottom of the cage as my solvent squirter. . Smiley , then Ill write some special software
blocks to allow control of 3d output from it.
 Ill post pics as I go for those that are intereste d on my 3d printer topic. These types of projects are good for GM as I get to do
tests in a work environme nt, find what pisses me off, and fix it before you guys get too pissed at the same type of things.
Logged
Thanks, have fun,
Administrator
Hero Member
View Profile
« Reply #17 on: April 19, 2011, 08:42:01 AM »
  If you search for "3d puzzle" in google, youll find a german site that has several DXF's that make those objects from plywood or whatever. All you have to do is scale them to the material thickness by checking the width of the tabs and scaling so the tab width is the same as the material thickness . We had to scale up that eagle for 3mm plexi.. so it got pretty big. Impressiv e though.. Bob took it home to make a lamp from it.. I think he loves my laser more than I do. :-)
  That eagle takes about 20 bucks worth of plexiglas s. ( Likely about 2 bucks worth of 1/8th inch plywood. )
Logged
Thanks, have fun,
markwoodard41
Newbie
View Profile
« Reply #18 on: April 19, 2011, 10:15:42 AM »
Your eagle is very impressiv e. Thanks for the tip on the plans.    I'll have to see what I can do in wood with a poor man's laser. Oops.   I mean router.
Mark
Logged
Administrator
Hero Member
View Profile
« Reply #19 on: April 19, 2011, 10:45:19 AM »
Hi Mark:
  Should be easy with a 1.5mm bit in 1/8 plywood. Yell if you cant find the site.. I'll look it up again..
Logged
Thanks, have fun,
Full Member
View Profile WWW
« Reply #20 on: April 19, 2011, 11:17:20 AM »
Thanks for the details.
Logged
markwoodard41
Newbie
View Profile
« Reply #21 on: April 19, 2011, 12:48:14 PM »
I am traveling so can only use my phone. Is this it?  It's kind of hard to see on this small screen.
http://www.woodworkersworkshop.com/resources/index.php?cat=452&page=2&topic=wooden%20puzzles
Mark
Logged
Sr. Member
View Profile WWW
« Reply #22 on: April 19, 2011, 01:38:56 PM »
Mark;
 Yes that's it..They have all kinds to pick from as dxf, fun little puzzles to cut and build, mind you they come without any instructi ons though..l ol As Art said I added a small strip of mood LED's behind the eagle to give it that cool effect at night. I like it but my wife doesn't, meaning it will have a short life span..lol Would like to see it construct ed  in multiple colors though, I think it would stand out a lot more than it does...An yway Art is right, I do like his new Laser Toy, it works very well indeed, I'm still in the WOW mode.
Bob Smiley
Logged
Ken_Shea
Jr. Member
View Profile
« Reply #23 on: April 19, 2011, 05:30:03 PM »
Mark, or others.
These two links should keep you busy for a while.
http://www.cnczone.com/forums/diy-cnc_router_table_machines/5276-dinosaur_skeleton_other_models_dxf.html
http://www.cnczone.com/forums/general_metalwork_discussion/19346-share_your_files_part_art.html
Ken
Logged
tweakie
Newbie
Super Kitty
View Profile WWW
« Reply #24 on: May 04, 2011, 11:15:29 AM »
Nice work Art.
Acrylic and lasers were just meant for each other.  Grin
Logged
Pages: 1 [2]
  Print
Jump to:
