GearHeads Corner
May 21, 2013, 07:26:01 AM
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
GearHeads Corner
General Category
Gear Discussions
Removing Gears from Project Data Base
Pages: [
1
« previous
next »
Print
Author
Topic: Removing Gears from Project Data Base (Read 176 times)
Full Member
on:
April 11, 2011, 07:51:43 AM »
I am involved in a kinetic sculpture and as such the visualiza
tion of the "product" changes as the project evolves. There are occasions when my design will have 3 or four layers of the same gear that overlays the previous one. I can "hide" them easily enough but I would really like to eliminate them so that they don't come back to "haunt" me.
Once a gear is placed it appears to be fixed and permanent
. I can start the project over again but that is a pain.
Logged
1% inspirati
on 99% try, try again
Administrator
Hero Member
Re: Removing Gears from Project Data Base
Reply #1 on:
April 11, 2011, 08:06:25 AM »
Unfortuna
tely, you can remove a gear only if your willing to remove all gears forward from that gear.
( Just right click the gear and select Remove Train. ). You can easily remove it if it was placed last..but it gets more complex if it
has several gears running off it..
There are technical reasons for this limitatio
n.. the program would get very confused if a gear in the train was lost, without all gears forward to it being lost as well.
Logged
Thanks, have fun,
Full Member
Reply #2 on:
April 11, 2011, 03:15:53 PM »
Nice picture, John! The internal/external overlaid gear is pretty cool, too.
Changing a gear once it's placed is a real pain. Art, would it be possible someday to do something like exploding a gear train - remove all the gears and place them across the top of the screen with no connectio
n, say? Then allow individua
l disconnec
ted gears to be deleted and use drag and drop to put the survivors back, adding new gears along the way. "Will it mesh" might make this trickier, but it already allows incompati
ble elliptica
l gears (added a 5 tooth to a 21 tooth OK, but the pinion won't rotate onscreen) so it could just be "designer beware". Way down on the priority list, of course. Or is this too big a project?
John, do you have any photos of finished projects you could post in show and tell?
Logged
Administrator
Hero Member
Reply #3 on:
April 11, 2011, 08:35:49 PM »
It sounds unbelieva
bly complex.. but Ill keep it in back of mind..
Logged
Thanks, have fun,
Pages: [
1
Print
« previous
next »
Jump to:
Please select a destination:
To Join Forum, please email Support@gearotic.com
=> To Join This group, please email support@gearotic.com
General Category
=> Newest Rev Release
=> Bevel Machining Discussions
=> Registered Users
=> Gear Discussions
=> Support and Bug Reports
=> Suggestions for Future
=> Third Party Software
=> 3d Printers Discussion
=> Conventional Gear Cutting forum
=> Contest Entries
=> 3D Printer Examples
User Video Links
=> User Photo's ( Show anfd Tell)
=> Your Videos
Loading...
