One thing Im very meticulou
s on is to not touch Gcode routines that work. The 4th axis routines I am VERY carefull about simply because they are
so hard to test. They have their own code classes , one for helical, one for bevels, and they havent changed since your helical tests to the best of
my recollect
ion. They dont even use the solid models just in case I should change something there, the helicals and spur gear 4th axis actually use only
the internal parameter
s of the gear ( PA, Module, root diameter etc.. ) to keep them separated
. I do this so I dont have a "Doh" moment because I hate
setting up my 4th axis to do the testing.
