GearHeads Corner
May 23, 2013, 07:16:57 AM *
Pages: [1]
  Print
Author Topic: Changing a gear after you've added it to project  (Read 213 times)
Geeksgonebad
Newbie
View Profile WWW
« on: December 27, 2010, 08:20:08 PM »
I'm a new user so if this already exists then please ignore Smiley
but I was playing around with making a planetary gear and wished I could change the gears (and make copies of gears I already had) after I already added them to my project and wanted to play around with different teeth counts and such - as it was I had to delete all the gears and start all over adding them
So I suggest being able to change the gear (and maybe make instances of an already created gear / copies) after you've added it Smiley
Logged
Check out my CNC projects (and more) at http:// www.backy ard-workshop.com
Administrator
Hero Member
View Profile
« Reply #1 on: December 27, 2010, 09:44:02 PM »
  Copying gears will come shortly.. deleting one gear is possible, but you have to right click it in the project screen, and select delete. BUT , any gears connected to it forward in the chain will also delete. They have to, byu changing one gear, you invalidat e all the ones connected to it.
Logged
Thanks, have fun,
Pages: [1]
  Print
Jump to:
