Salvador;
Thanks for the post. I'm not sure I understan
d your question perfectly but every time you change a gear setting in GM, it will remember these changes and will continue to use them until you change something else. If program is restarted, now default values will be used. Once you have made any changes to a gear in GM and saved it using the output manager, a (
Involute-001-Params.tx
t) will be generated to ease with reproduci
ng the same gear all over again should it be required. As to re-establishing your old parameter
s with a restart could be more problemat
ic than good if you'd forget to select something simple for example, so is best in my opinion to keep it this way. Your idea is noted and will under go review, thanks...
