I looked up some informati
on about the type of virus warning being triggered
. I've tried to make some sense of the types of things Windows is concerned about as described in:
https://www.malware-board.com/blog/remove-trojanwin32-spursintfcl-from-pc-simple-processThe name of the file probably has nothing to do with the detection
. There is perhaps some sort of windows feature where your programs are calling Windows system functions (probably defined in a windows system .dll file) to execute external .exe files or to get informati
on from memory locations external to the running program.
One example comes to mind: the relations
hip between Vexx and Gearotics to get a gear from Gearotics, modify it in Vexx and then replace the modified gear back into Gearotics might resemble behaviors similar to the Trojan.
I'm not too familiar with Augie except for the simulatio
n capabilit
ies where pressing CONS button brings up another window.
After I re-enabled detection of Trojan virus as soon as I tried to rename Gearotics
Setup.exe
to a different name the system once again not only deleted the file I tried to rename but it also deleted the different versions of CoInstall
.exe and Gearoitic
s within the same windows folder.
To say that the virus protectio
n is aggressiv
e would be an understat
ement.
Bill
