GearHeads Corner
May 26, 2013, 04:42:06 AM
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
GearHeads Corner
General Category
Suggestions for Future
Mold code
Pages: [
1
« previous
next »
Print
Author
Topic: Mold code (Read 408 times)
Monafly
Newbie
Mold code
on:
November 06, 2010, 10:44:45 PM »
Would it be feasible to add an output option to generate G-code for a mold for the desired gear instead of the gear itself?
Thanks.
Logged
Administrator
Hero Member
Re: Mold code
Reply #1 on:
November 07, 2010, 08:05:56 AM »
No, I dont think thats feasable. Moulding requires a full 3d Gcode program be put out, but there are so many ways and options in doing that , that it requires a full 3d cam program. SO while the 3d model could be used by such a cam program to create the mould, its out of the scope of a small(?) utility program like Gearotic Motion to do such a thing.
Logged
Thanks, have fun,
Monafly
Newbie
Re: Mold code
Reply #2 on:
November 07, 2010, 01:17:26 PM »
Maybe a full mold is out of the question, but what about code to cut a 'stencil' instead of the gear. For a simple spur gear (or any of them) this would cut the inside of a sheet leaving the gear pattern as a hole. Think of puzzle pieces-the gear and a gear shaped hole that fit together. It would be same as cutting the gear with an infinitel
y thin cutter with no lead ins etc. This would be as 2D, not using a rotary axis.
Thanks.
Logged
Administrator
Hero Member
Re: Mold code
Reply #3 on:
November 07, 2010, 01:26:24 PM »
hmm, that would probably work now just by doing a 2d cut with a .000001mm diamter tool..
Logged
Thanks, have fun,
Monafly
Newbie
Re: Mold code
Reply #4 on:
November 07, 2010, 01:39:19 PM »
Opps-a minimal diameter cutter would make the example I cited, but I want to cut the stencil with a real cutter but end up with a gear shaped hole. For a spur gear this would be the equivalen
t of making an internal gear and can be done at present for spurs, but not for any of the others. Maybe would be a better way to make the request-allow eccentric and imaginary 'internal' gears to be made and cut with real sized cutters.
Thanks.
Logged
Administrator
Hero Member
Re: Mold code
Reply #5 on:
November 07, 2010, 03:15:28 PM »
Hmm, internals I dont think would work well, but eccentric
s would. Unfortuna
tly the method of eccentric generatio
n I use is a osculatin
g circle method, to really do an eccentric that can be internal ring geared I need to use a constant pressure angle algorithm
. I plan on developin
g such a beast after I get a few more things done, including the bevel gears.
Logged
Thanks, have fun,
Pages: [
1
Print
« previous
next »
Jump to:
Please select a destination:
To Join Forum, please email Support@gearotic.com
=> To Join This group, please email support@gearotic.com
General Category
=> Newest Rev Release
=> Bevel Machining Discussions
=> Registered Users
=> Gear Discussions
=> Support and Bug Reports
=> Suggestions for Future
=> Third Party Software
=> 3d Printers Discussion
=> Conventional Gear Cutting forum
=> Contest Entries
=> 3D Printer Examples
User Video Links
=> User Photo's ( Show anfd Tell)
=> Your Videos
Loading...
