GearHeads Corner
May 18, 2013, 10:07:00 PM *
Pages: [1]
  Print
Author Topic: Mold code  (Read 399 times)
Monafly
Newbie
View Profile
« on: November 06, 2010, 10:44:45 PM »
Would it be feasible to add an output option to generate G-code for a mold for the desired gear instead of the gear itself?
Thanks.
Logged
Administrator
Hero Member
View Profile
« Reply #1 on: November 07, 2010, 08:05:56 AM »
   No, I dont think thats feasable. Moulding requires a full 3d Gcode program be put out, but there are so many ways and options in doing that , that it requires a full 3d cam program. SO while the 3d model could be used by such a cam program to create the mould, its out of the scope of a small(?) utility program like Gearotic Motion to do such a thing.
Logged
Thanks, have fun,
Monafly
Newbie
View Profile
« Reply #2 on: November 07, 2010, 01:17:26 PM »
Maybe a full mold is out of the question, but what about code to cut a 'stencil' instead of the gear. For a simple spur gear (or any of them) this would cut the inside of a sheet leaving the gear pattern as a hole. Think of puzzle pieces-the gear and a gear shaped hole that fit together. It would be same as cutting the gear with an infinitel y thin cutter with no lead ins etc. This would be as 2D, not using a rotary axis.
Thanks.
Logged
Administrator
Hero Member
View Profile
« Reply #3 on: November 07, 2010, 01:26:24 PM »
hmm, that would probably work now just by doing a 2d cut with a .000001mm diamter tool..
Logged
Thanks, have fun,
Monafly
Newbie
View Profile
« Reply #4 on: November 07, 2010, 01:39:19 PM »
Opps-a minimal diameter cutter would make the example I cited, but I want to cut the stencil with a real cutter but end up with a gear shaped hole. For a spur gear this would be the equivalen t of making an internal gear and can be done at present for spurs, but not for any of the others. Maybe would be a better way to make the request-allow eccentric and imaginary 'internal' gears to be made and cut with real sized cutters.
Thanks.
Logged
Administrator
Hero Member
View Profile
« Reply #5 on: November 07, 2010, 03:15:28 PM »
  Hmm, internals I dont think would work well, but eccentric s would. Unfortuna tly the method of eccentric generatio n I use is a osculatin g circle method, to really do an eccentric that can be internal ring geared I need to use a constant pressure angle algorithm . I plan on developin g such a beast after I get a few more things done, including the bevel gears.
Logged
Thanks, have fun,
Pages: [1]
  Print
Jump to:
